Could you kindly give me a solution for firedamper?
Now I face a problem that the peneteration from ECR Room to Main Switch Board Room (A-0 Bulkhead) is 1000x400 in size.Do I need the firedamper for this peneteration?.This is the ABS Class Lifting Boat Project
RE: Could you kindly give me a solution for firedamper?
My half a cent.
The rating of the wall is generally set by the project architect, and is code driven.
