in slab heat tubing
in slab heat tubing
Have a job where they are using in in-slab heat tubing ~5/8" diameter. They want the tubing on top of the welded wire fabric ~1" clear from the surface of the slab-on-grade which puts the WWF in the middle of the slab. We specify that the WWF is to be in the top 1/3 of the slab thickness.
I've expressed my concern about slab joints and they say the will work around them.
Curious how others detail this condition.
RE: in slab heat tubing
As far as the WWF in the middle third not a big deal in my book. Like the previous post said half the time I imagine it is located in the dirt with residential work.
Consider getting rid of the wire altogether and going with fiber mesh. Then they can't screw it up.
