Why Use Isolation Transformer to Feed Motor
I recently worked on a project where they had an Isolation transformer 4160V to 4160V. I could not figure out why they would use this set up to feed a motor. Any thoughts?
RE: Why Use Isolation Transformer to Feed Motor
The other possibility would be to limit the ground fault current that could flow into the motor stator windings if the motor goes to ground. Even a wye-wye transformer will limit the ground fault current quite a bit.
JIM
