no geometry in imported model
hi everybody
if i import an inp file in my CAE using import model i seem to not be able to calculate the volume of an instance because i don't have geometry (something like that).
now, since i need to calculate the volume of my new object created by modifying the input file, how can i do that?
thank you all!
thank you all!
RE: no geometry in imported model
i think that could be what i was looking for if it wasn't that i think (i'm not sure, gotta check tomorrow at work) i'm using 6.6... do you have any other suggestion if that's the case?
thank you all
Gurmeet
