Corrosion of anhydrous hydrogen chloride
Can anhydrous hydrogen chloride gas and liquid be corrosive to SA-333 steel and stainless steel at low temperature? Could anyone be kind to provide some references about them? Thanks.
RE: Corrosion of anhydrous hydrogen chloride
this is a good reference for Ni alloy and Stainless Steels.
Nickel Resistance (279)
Previews of service experience plus numerous laboratory and plant corrosion tests on the performance of nickel and nickel alloys in contact with chlorine, hydrogen chloride and hydrochloric acid. Discusses organic chlorinations, synthetic resins and rubber, petroleum refining, and pickling solutions.
http://w
Corrosion Resistance Data
S.
Corrosion Prevention & Corrosion Control
Upset conditions, start-up etc. will all have to take this into account. The least little bit of water present in the line WILL become aggressive hydrochloric acid in this service...
