3D solid to 2D drawing that shows GDT and part notes
I have been given a 3D solid model Catia V5R19 and need to creat my own 2D drawings. The one problem I'm having is getting the GDT and selected part notes into the new drawing. I can copy and paste from the solid to a word doc. But I have not been able to do this to the 2D print.
RE: 3D solid to 2D drawing that shows GDT and part notes
http://mtm-cadtutorials.blogspot.com/
Pretty much after I have the 2D sheet open and I click on the icon to view from 3D I'm stuck.
Please forgive my inexperience.
see attached video.
Roadking: you should check with your customer to get their advice on how to access the data. Different companies do things differently. I think some companies add notes as parameters, while other may use 3D annotations for notes as shown in the video. I'm not sure how you would access BOM info, unless you had access to their PDM system.
I am in the same boat as Roadking77.
I just received a part which has the Functional Tolerancing and Annotation(??) incorporated into the model.
I am following the steps from m1mason's excellent video but the view does not remain visible in drafting, that is, I see the preview but when I accept it it disappears. Perhaps there is a setting I need to toggle? I also don't have the FT&A module but I can still see the notes and GD&T.
Any tips?
thixoguy
Mark
Expand the Annotation branch at the bottom of the tree, so that you see all the FT&A views. Then try making your drawing view by selecting one of the 3D annotation views.
I don't think you need the FT&A license to do this.
I figured it out. The view when placed in Drafting was placed way out in space. Reframe found it.
Thanks to m1mason for the generous offer.
Thanks to jackk for his usual input
thixoguy
