Mirroring of Surface Parts
I am doing an FEA of a component that has several large diameter pipes that are generally mirror images of each other. I have chosen to run shell elements for the pipes and would like to know if anyone has a method of mirroring surface parts which shells require.
RE: Mirroring of Surface Parts
Surface bodies can be mirrored within a part.  Select bodies under the "Bodies to Mirror" tab in the mirror dialog.
