MDMT for black iron pipe
Am starting a new design project and am trying to find the MDMT for a segment of black iron pipe that's in an exiting system. Was wondering if anyone could provide some assistance.
MDMT for black iron pipeMDMT for black iron pipe(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: MDMT for black iron pipe
What is the design code and material spec?
And I'm not sure what is the exiting system, is it something related to the high security prison and carrying almond smelling gas or simiar?
cheers,
gr2vessels
To determine its minimum design temperature of a pipe, just knowing it is "black iron" and "2 inch diameter" is not enough.
If the pipe was made prior to about 1975-1980, it could have a ductile to brittle transition temperature above 100F.
Current operating conditions: 50 psig, ambient temp, pipe is fairly new (within 10 yrs).
Does the pipe have threaded fittings? Often steel pipe is called "cast black iron".
This is a guess.....but I bet that I am right..
"Black Iron" small bore pipe is usually A53 Grade B carbon steel.
Use ASME B31.1 to find MDMT properties etc.
Be aware that, if the system uses those cheap-ass malleable iron fittings, you are limited to both a maximum (400F) and minimum temperature by those fittings....not by the pipe.
My opinion only
-MJC
If this is in a typical bottle filling plant the fittings were probably purchased at Home Depot or equal.
Looking at B31.3 if you have "Type F" (continuous welded)A53 Grade A a +20F minimum design temperature is permitted.
It looks like all other A53 grades and production methods allow a -20F minimum design temperature.
