Need material recommendations
I have an application where I need to provide a pump that pumps a 25% concentrate magnesium chloride from a pond. My main concern (or question) is about the volute and impeller material. From what I've read, magnesium chloride is fairly corrosive.
Has anyone worked with pumping a solution such as this and what types of materials could you recommend?
RE: Need material recommendations
Carbon graphite, hastelloy, rubberize the volute and impeller, etc.... Or just do a sacrificial pump analysis with CS, which will last a bit
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
>5% magnesium chloride PFA(virgin teflon) and TEFZEL are recommended
You aklso need to consider any other wetted area's such as the seal area / shaft sleeves/ seals etc, also - what are you doing for pipe work including any valves needed for the system?
PFA or ETFE lined are often used for such applications.  Mag drive could work subject to a few more parameters being defined, or slurry seal if solids present (single or double arrangement)
Ash Fenn
www.cdrpumps.co.uk
