PLOTTING OR PRINTING DRAWINGS
Is there a way to plot or print drawings without opening up the drawing?
RE: PLOTTING OR PRINTING DRAWINGS
Don't think I did anything with it after V10 came out in 1995.
Ben Loosli
Bill
I'm pretty sure there was grip about to do it and that we discovered XSPAWN to lauch a simple command line script that made a file listing from DCL all the way thru batch files at the point where GRIP development discontinued and the printing method had changed to something no longer addessable in UG-NX. However these days I would think you could still do something using NX-Open programming but the problem as always is that we're sadly lacking for something like the old GRIP programming library whereby the distributed samples offered inexperienced and amateur programmers a launching pad to modify other people's code to good effect. As I mentioned any program that could be shared in this vein would be heartily appreciated.
Cheers
Hudson
NX 5.0.3.2 MoldWizard
