Transformer protection
Dear colleagues,
The NEC 2005 Article 240.21(C)(1)permits to consider multiphase transformer secondary conductors to be protected on primary side of the transformer ONLY for delta-delta connection. How to explain this limitaion and why OTHER THAN delta-delta connections are not considered to be protected by the primary overcurrent protective device?
RE: Transformer protection
For delta-wye transformer, compare the current seen on a primary OC device compared to the current flowing in the secondary winding for a secondary line-to-ground fault.
