SaveAs pdf Macro disclude one sheet
I have done some searching on this topic. Reference:
thread559-122404: Save as PDF drwing sheet control.
thread559-163578: Save as PDF example code
thread559-158861: PDF Macro Help
thread559-122404: Save as PDF drwing sheet control. specifically is addressing my issue, but this was back in '05, so I am wondering if anything has changed.
My issue is this, I have 3 (sometimes 2) sheets on a drawing, the last sheet is always renamed to DXF and it is a flat pattern of a sheetmetal part. When I use a macro to saveas pdf, I would like it to not include the DXF sheet. Ideally I don't want to go the route of print to pdf, but if that is the only option, I will go there (primopdf). I don't seem to see an option when I SaveAs4 to select which sheets. It seems odd, because when I manually do a save as pdf, I am prompted which sheets I want to include.
Thanks in adavnce for the help. I have already received help from fcsuper. It is his macro that I tweaking for my needs.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
RE: SaveAs pdf Macro disclude one sheet
-handleman, CSWP (The new, easy test)
Thanks again.
-Dustin
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
