cafe heating/cooling load skylight
skylight 25x25, with 16 bronze tinted skylights. will be a cafeteria underneath for 10-15 people. 14 ft high walls. constant volume system.
With U=1.0 and SC=0.73 for a singele 1/4" coated skylight, the cooling load comes to ~ 10 tons (4500 cfm) with Trace 700.
What is good estimate of U-value, SC.
Is 4500 Cfm too high? total area is 600 sf. almost 8 cfm/sf? what is good tonnage estimate?
pic attached.
RE: cafe heating/cooling load skylight
Project in washington dc. interior space with its own interior walls.
Single pane glass? If so, SC = 0.8 is not a bad number, U = 1.1.
25"x25" or some other unit?
10 tons / 600 sqft = 60 sqft / ton.... which is pretty high. Typical cafe numbers would be 200-400 sqft/ton (from rules of thumb).
25 FT X 25 FT. THE WHOLE  CAFE IS 25 FT X 25 FT AND ENTIRE ROOF IS MADE OF SKY LIGHTS. A GRID OF 4X4- EACH ONE IS 6 FT X 6FT WITH ALUMINUM FRAME SO 6X4=24 FT PLUS ALUM MAKES IT 25FT X 25 FT. IT HAS BROWN TINT AND IS 3/16" THICK. AT 200 SF/TON = 3 TON WOULD BE LOW. 7-8 TONS SOUNDS BETTER??
7 TONS X 400 CFM/TON = 2800 CFM. ABOUT 5 CFM/SF.
IS 5CFM/SF TOO HIGH?
A typical house rule of thumb is about 1 ton/600 sq ft, but even that's overkill, at least, for Orange County in California.  We're running 1 ton/700 sq ft with no problems, here.
You're essentially wanting to put about 6-7 times the capacity of what a typical house might need.  I could see going 1 ton/200 sq ft, because of the humidity and higher body and equipment load.
Are you thinking you need to freeze everyone so that the turnover is higher?
TTFN
Any higher solar loads. Most houses don't have glass roofs.
True enough, but we do have skylights and our roof is essentially drywall, whatever's left of the original  blown-in insulation, plywood, and aluminum.
TTFN
