1018 CRS 3" x 4" Bar failure during rolling
Hello all,
We have a job to roll four 3" x 4" x 12' 1018 CRS bars to 97" IR. There are two heat numbers (3 bars with one number, 1 bar with one number) which were never marked on the bar by the supplier as MTRs were not required. The first bar rolled perfectly. The second bar sheared approx. one foot into the rollers on the first pass, prior to any real pressure being applied. Third bar rolled fine. Fourth bar sheared approx. two feet in on the first pass with slightly more pressure then the first bar that failed. Our roller operator is very experienced so I've taken operator error off the table.
I contacted the supplier and immediately he began to tell me we should have orderd hot rolled as CR is harder and more brittle, however we've used 1018 CR bar of this type and size before with no problem. My question is, should we go with HR in the future (and for replacement material for this job) and if so, what are the critical differences in properties between 1018 HR/CR as far as rolling goes. Any help would be greatly appreciated.
RE: 1018 CRS 3" x 4" Bar failure during rolling
I believe HR will be OK as the only thing you really gain is in the bar finish. If you can get the HR in TGP it should work better.
I've always taken that rolling CR mild steel at or above Rb 80 was a gamble. We always like to roll in direction of plate forming roll, parallel to the mill rolling direction, which is impossible in rolling a hoop.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
