Hose testing for Hydraulic steering
Which is the Standard that handle the test for Hydraulic Hose used at hydraulic steering sytems in Cars and small truck. I have a brief description of the procedure , For return or suction hose . start at 0 Barg , rise to 4 Barg in 0.2 second, hold at 4 Barg by 0.4 sec , down to 0 bar in 0.2s and hold at 0 barg while 0.8 sec , for hig side pressure , lower press is 4 Barg , and upper is 6 Barg , same rates and time. The hose have 610 mm with 1 offset at middle. I read about it can be D-380 , but after a search , I do not get a scope for such standard.
