Shrinkage Compensating Concrete Slab
I am interested in some feedback from people who have experience using shrinkage compensating concrete for slab-on-grade applications. I am considering using this as an alternate to a post-tensioned slab. I need a monolithic slab/grade beam/footing foundation due to expansive soils so it makes crack control difficult. I have seen problems occur when slabs and footings are cast monolithically due to the restrained condition but I need a stiff foundation/slab.
Thanks for your input.
RE: Shrinkage Compensating Concrete Slab
2. Post-tensioning will not provide crack control in a slab with restrained edges unless the strands are bonded. Even if they are, for a strong degree of crack control, you will need some additional deformed bar reinforcement.
Also, shrinkage is not the only source of shortening. Temperature change will be at least as significant and possibly more so depending on the temperature at time of construction and the general working temperature.
The use of shrinkage compensating concrete is well documented. You are correct that all concrete shrinks, but shrinkage compensating concrete expands (first seven days or so) before it starts to shrink. The concrete goes into compression as it expands and this offsets the tensile stresses that cause shrinkage cracks when it starts to shrink. I have never used it on a job and I am interested in some firsthand knowledge.
I am not sure about your second comment. Post-tensioning whether bonded or unbounded produces a compressive stress on the concrete. This compressive stress helps to counteract the tensile stresses caused by shrinkage. Why do you say that "Post-tensioning will not provide crack control in a slab with restrained edges unless the strands are bonded?"
I think the most important parameter to watch out for is the end restrains around the elements that using "shrinkage compensating concrete". As you pointed out correctly - it expands, thus create permenent stresses on the confining elements. You may avoid that effect by carefully planning concrete casting sequence, and locating construction joints. Do you rebas in the slab?
Thanks for the clarification. That makes sense.
The floor pours were made in 10,000 sf sections, no joints, no column boxouts and finished conventionally. That floor is still crack free even with all the forktruck traffic that it has had over the years.
Now, the reason this never really caught on is the added cost. The increased amount of reinforcing, the fact that at that time the ready-mix supplier had to order the Chem-Comp cement in bulk and empty his bins just for that job, and the large on-site construction crew to pour and finish the slab.
Today, you can get additives that are put in the ready-mix truck at the site, concrete pumps are readily available, as well as riding finishing machines all of which reduces the cost.
