al6xn vs hastelloy c276
Does anyone have a chart or quick reference on the corrosion resistance between al6xn and hastelloy c-276.? in a citric acid environment to be specific
RE: al6xn vs hastelloy c276
Why not use 316SS?
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
I wish....not an option
Best I can do for you is: http://www.coleparmer.com/techinfo/chemcomp.asp but you probably need tables at different concentrations and temperatures, which this will not give you
Outokumpu shows a 6%Mo alloy suitable clear to 70% boiling.
Unless you have a lot of Cl contamination 6XN should work fine.
Plymouth Tube
