Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site was well structured and I found what I was looking for in about 2 minutes. I am looking forward to participating with you in the future..."
Geography
CADone (Mechanical)
11 Nov 08 10:39
Just by looking at a sketch is it possible to tell if a sketch is fully constraint. Any color codes?
btrueblood (Mechanical)
11 Nov 08 11:07
On my installation of Inv 2009 (and was this way for all prior versions back to R10, default color settings) the sketch lines change from green (unconstrained) to black (fully constrained).
mcgyvr (Mechanical)
11 Nov 08 11:49
In 2009
#1 line colors change as stated above.
#2 in the bottom right hand corner (around the memory meter area) it will also tell you how many dimensions you need as well as saying when its fully constrained.
rollupswx (Mechanical)
11 Nov 08 12:50
In addition to the color change for fully constrained sketch and the prompt in lower right corner of screen
- you can also turn on visibility of Degrees of Freedom for sketch entities or use Autodimension to add constraints and/or dimensions.
Close Box
Join Eng-Tips® Today!
Join Us             Close
