Data for index of refraction as function of wavelength
I am looking for data for index of refraction as a function of wavelength for optical glasses over a large wavelength range (400 to 1,000 nm). Ideally, I am looking for a plot of index versus wavelength over that range. (The Abbe number describes how much index of refraction changes with wavelength, but only for certain specific wavelengths, and I need a wider range.)
Thank you.
Dale C.
Library Manager
Thank you.
Dale C.
Library Manager
RE: Data for index of refraction as function of wavelength
TTFN
Thanks for taking the time to respond.
-Dale
TTFN
If you add the wavelengths you are interested into the design you can then bring up the prescription with the Index/CTE option checked. It will have the index for all of you glasses at the wavelengths in the design.
If you are using CodeV it is probably similar, I just don't use it so I don't know the details.
HTH
Dan
