Finite Element Transient Simulation
I am currently performing some transient simulations in FLUX (a finite element package released by Cedrat) with an induction motor. I have run the motor up to speed under no-load condition and everything seems to work as expected.
Now, once loading the machine with a step torque (100 Nm) by using a Transient Startup feature of FLUX I have noticed some rather strange results. I have attached two curves for you to have a look at, these are speed and Axis Torque. As you can see, there is for some reason a steady state reached and then a transient after a second or two which is then repeated along the rest of the simulation.
I have run equivalent simulations in Simulink using the built-in Asynchronous motor model built into the Simulink SimpowerSystems library, with results also attached.
Your help in this regard would be greatly appreciated if you could explain to me exactly why this is happening.
Thank you.
RE: Finite Element Transient Simulation
Can't see any curves. Upload files by using the attachment feature at the bottom.
corus
