Welding hardened steel camshaft gears
I am hoping to repair the pitted gears on a steel camshaft by
mig welding. The gears are hardened but I am not sure if by
induction using a case hardening steel or by carburising and
heat treating. Is it feasible to use Mig, bearing in mind that
the gear is hardened? The drives are to distributor and oil pump
so the loading is not very high. I am more concerned with
reestablishing a flat surface which will maintain hydrodynamic
lubrication (without surface failure due to HAZ problems) than
reestablishing the original hardness although if this could be
achieved that would be very desirable. Can anyone suggest a
better method. I also have oxy acetylene.
Thanks for your help.
Regards Gus
Regards Gus
RE: Welding hardened steel camshaft gears
