Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
ozziz (Structural)
11 Nov 08 3:23
Appreciate views,information and opinions on immature concrete subject to lateral loads.
The contractor has to install steel tubular piles for construction of wharf into rock sockets. The concrete specfied is 40 MPa at 28 days strength. The contract calls for the piles to be temporary braced. But the contractor wanted to release the braces after 7 days when the strength is around 25 MPa. This means the concrete is immature and has not reached its 95 % full strength. Question is will the concrete pemanently deformed if the lateral loads such as wave, current is excessive? Where can I source inform on strength of immature concrete?
SlideRuleEra (Structural)
11 Nov 08 10:35
American Concrete Institute address loads on immature concrete in their document ACI-347, Formwork for Concrete.
Typically, problems occur if the loads cause cracking.
Google Books has a preview of ACI-347. Fortunately, Section 5 - Loads & Pressures is complete in the preview. See the information starting on Page 5-18. Here is the link
http://books.google.com/books?id=0G9n7dfIvNEC&pg=PT111&lpg=PT111&dq=loads+on+fresh+concrete&;source=bl&ots=zSDcN7pZNz&sig=ji3-w051uhF9j0ykiG5aW-mG_wE&hl=en&sa=X&oi=book_result&resnum=1&;ct=result#PPT104,M1
For your situation, of course the easy answer is to tell the Contractor "NO". But, IMHO, that is not what engineering is about.  Take a look at the live loads that the wharf was designed for (perhaps ship mooring or impact?). If those loads are large compared to wave, current, etc. and will not occur while the concrete is curing, perhaps you can consider allowing the Contractor's request.
If your look at the numbers is encouraging, have the Contractor submit to you a detail plan of exactly what he plans to do (prepared by an independent Engineer, at the Contractor's expense).  If the plan is reasonable, accept it.
www.SlideRuleEra.net idea
www.VacuumTubeEra.net r2d2
ozziz (Structural)
17 Nov 08 3:54
SlideRuleEra
I look up at the reference Formwork for concrete as recommended, it does not mentioned about loadings on young concrete. The book is more towards formwork and concrete pressure on formwork
17 Nov 08 8:42
Ok, you could try "ASCE 37, Design Loads on Structures During Construction".
I have not seen this document, so cannot say if it addresses your concerns. Here is a link:
https://www.asce.org/bookstore/book.cfm?book=4242
Close Box
Join Eng-Tips® Today!
Join Us             Close
