Anyone ever see a double positive tolerance?
Anyone ever see a double positive tolerance? (e.g 1.000 +0.005 +0.008)
I've always thought the target value must be between the maximum and minumum value; and was selected by the engineer based on maximizing yield depending on how the part would be made, and on maximizing performance of the final assembly. The tolerances could be symmetric +/- 0.003, or they could be asymmetric +0.003 - 0.000, but I've never seen double positive tolerance, or double negative before.
Did I miss something in GD&T class?
RE: Anyone ever see a double positive tolerance?
I use them all the time.
Try to search before posting. This has been discussed before.
Here's on example.
http://www
V
I agree with the others.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
It usually results in a call from the shop ("Am I understanding this correctly?" ... or some rude equivalent).
It's not a bad way to:
- get acquainted with the guys in the shop.
- find out they are really working on your project.
Mike Halloran
Pembroke Pines, FL, USA
Joe
SW Office 2008 SP4.0
P4 3.0Ghz 3GB
ATI FireGL X1
You can review information on this subject here:
http://w
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
By extension some German drawings seem to use them even on items that aren't a classic 'fit' situation.
They can cause confusion so I avoid them. Also with some CAD systems it can be awkward to achieve.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
-handleman, CSWP (The new, easy test)
"It's not a bad way to:
- find out they are really working on your project."
I would add
- find out if they really read your drawings
Dave D.
www.qmsi.ca
I create part drawings that reflect the desired geometry of the part. Things like sliding fit or other design intent information belong in the project design file, not on the drawing.
On the other hand, places that are used to them can most likely handle nominals with +-, or max min, just fine.
So, unless I'm sure all potential users of the drawing are fine with them (not just now but in forseeable future) I'll convert to either limits or nominal with +-.
KENAT,
Not sure I see your concern on the assy drawings either.
KENAT,
I hadn't seen the practice before and I didn't remember the practice being part of Y14.5. I thought that the target value was an important piece of information for the machinist; tolerances could be, and in some situations should be, asymmetric, but the target dimension was an important piece of the design.
OTOH I could see that if you just roughed all the dimensions in at 'nominal' and then just loaded the values from the ANSI B3.17 (Shaft Dia and Housing Bore) tables at the time you create the dwg, it could save engr time. It is the equivalent of using MAX/MIN dimensioning. The machinist then choses the target value based on the processes being used.
I don't believe it's in ASME Y14.5M-1994, though I dont' think 14.5 forbids it either.
KENAT,
If the guy on the shop floor has a DXF file and is programming a CNC machine, it might help to see what the actual as-drawn feature size is.
I try to remember to convert my +/+ dimensions in SolidWorks to limit dimensions. Either way, the CNC programmer has to pay attention.
JHG
I know plenty that 30g6 would be meaningless to, especially without the relevant ISO referenced on the drawing.
KENAT,
I do usually include the -0.007/-0.020 values along with the tolerance class.
Also, from what I understand, the machinist will not be aiming at 29.9865 anyway. If it's a shaft, he'll shoot for just under MMC. Lots easier to fix if he misses. It's easier to get to 29.993 by subtracting 0.007 from 30 than by adding 0.0065 to 29.9865.
If you put 29.9865±0.0135 on the drawing you have to have a gage that is accurate to .00005 which is pretty near impossible. Any machinist that is not familiar with the ISO system of fits should not be making your parts. Normally parts requiring these levels of precision are not going to be made by the illiterate. If they are being made in volume there are probably automatic gaging systems in place with nice green & red lights that anyone can understand.
However, if you don't need asymmetric tolerances, definitely don't use them.
Having picked my self up from the floor where I'd fallen laughing. For those of us not caught up in the big defense & automotive supply chains, but too big to have much say in who the parts get sent to, I'd be amazed if Purchasing/QA even considered that issue.
Even in the UK we rarely used the "30g6" form, we'd put down the equivalent dimensions. Only exception I can think of is for threads.
KENAT,
http://www.engineersedge.com/true_position.htm
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
I have a bit of a problem with the web site you suggested when positional tolerances are called "true position". ASME Y14.5M-94 states that per 1.3.36 on page 4 True Position means "The theoretically exact location of a feature established by basic dimensions." The term used should have been "positional".
I might be nit-picking but a suggested web page and training advertisement should use the correct terms to gain credibility.
Dave D.
www.qmsi.ca
I don't back any site personally or professionally, I just suggest some sites for reference occasionally. Engineers should 'always' refer to ASME Y14.5-94.
I don't always have the ASME spec in front of me because I'm either virtual or at another site. So, I usually just do a quick Google search and share some sites I think may help a little.
I agree with you they should use the correct terms. But unfortunately I sometimes don't have the time to peruse the sites first.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
On topic: ++ or-- tolerances are fine for fit tables, but I would never use them on a drawing. I either convert to limit dimensions or mean value with ± tolerance.
"Check a catalogue for dimensional drawings of anything - linear shafting, bushings, servo flanges, spacer blocks, dowel pins, raw steel dimensions... the list could go on and on. If there's any sort of fit involved, you will see unilateral tolerances. I'm constantly amazed at people's ignorance of this common practice."
The whole or should that be hole reason behind this is to standardise things so parts are readily available and interchangeable, if you accept that all these items and more have unilateral tolerances on them why should the parts that they fit not have as well? The other option is of course to make everything specials and increase your costs by about 400%.
If you work in a part of the world that does not understand what 30g6 means then by all means put 30 -0.007/ -0.020 but to put 29.9865 +/- 0.0135 is just plain madness as you are just increasing the cost for producing the part with no gain what so ever.
I to am constantly amazed at people's ignorance of this common practice, I am even more amazed that companies that are forced to increase their costs through not understanding them still remain in business, they wouldn't be here next month in automotive.
I'm contracted to a company where the division DRM disallows unilateral dimensions on drawings.
We must use "target" (i.e. mean) dimensions with ± tolerances; equal, or unequal, but no + or - 0.
It is a shop, inspection driven requirement, much to the dismay of engineering.
Zero position tolerance an exception, of course.
ajack, in the UK we had people that couldn't handle this so used to normally put limits.
KENAT,
