Temperature Stratification in Pressure Vessels
We have a pressure vessel that we pressurize to about 725 PSI, and process material inside of it. If the pressure vessel is pressurized in about ten minutes without additional heating, would you expect there to be a large temperature stratification in the pressure vessel? If so, how would you recommend solving it?
Thanks.
Thanks.
