How to specify env variables with mex
Newbie question.
I have environment variables pointing to include directories.  I'd like to write something like
mex fred.c -I$(dist)\include -L$(dist)\lib -l libs
The only problem is I can't find the syntax of the environment variables anywhere.  I've tried
$dist
%dist  - it takes the %d off and I'm left with ist
%dist% - takes the %d off but not the %\
$(dist)
%<dist>%
I've looked through the internet and as much help text as I can find on Matlab but I can't see anything.  Maybe they call it something completely different.
Can anyone tell me what the syntax is for environment variables?
RE: How to specify env variables with mex
I tend to do my MEXing from a Matlab command prompt rather than from a shell prompt.  That way I can build up my MEX command bit by bit and then eval() it.  I'd use getenv() to read from the environment and then insert the values.  This approach allows me to use the same build m-file for Windows and UNIX.
% Untested
dist=getenv('dist');
command = ['mex fred.c -I$' dist '\include -L$' dist '\lib -l libs']
eval(command)
- Steve
Yes I am working from the Matlab prompt.  Your solution works well.
