Ford Kuga Gear Ratio - Top Speed
Hi guys,
I am a bit stuck on the following issue:
I've got some gear ratio data on the Ford Kuga but by using it (6th gear, 0.564 and final drive 3.238) and the overall wheel radius (17 inch, 235/55 wheels = 345mm) I get a top speed of 89 m/s, which is far to high for this car - should be around 50 m/s. I am aware that obviously the top speed is depending on the road load and power supplied by the engine and therefore wont be that high in reality, however, I am wondering if I missed something out as I can't see the point in gearing your 6th gear so that it is theoretically possible to reach this speed. Wouldnt that just ruin all you acceleration? The engine develops its max power at 4000 rpm, my top speed calculations are based on 4500 rpm.
It would be great if you could comment on this. I am not working in this field, so therefore am not that knowledgable.
Best regards,
Chris
ps. The Calc I've done: (4500rpm*2*pi*0.345m/60)/(0.564*3.238)=89 m/s
Best regards,
Chris
RE: Ford Kuga Gear Ratio - Top Speed
Seriously. The overdrive ratios are there to keep rpm down for noise an fuel consumption reasons.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers for professional engineers
Pat
As Pat has mentioned, centrifugal effects in some tires can be huge (and, I suspect, intentionally so as a means of getting around certain competition rules involving engine rev limits and mandated axle ratios), but not so in more normal road tires. The Kuha does not sound like a vehicle that would need much slip in order to develop the traction required to attain 50 m/s, and slippage works opposite to centrifugal effects anyway.
Norm
