Deflagration Loads on Concrete Structure
I'm designing a concrete structure for deflagration loads. I'm using the FM 1-44 data sheet and the ACI 3-49 code. Does any one uses another publication. Thanks
RE: Deflagration Loads on Concrete Structure
You might want to look at:
ACI216 - Fire Resistance and Fire Protection of Structures (Joint ACI-TMS)
Depending on the type of structure, you might want to look at the various NFPA (National Fire Protection Association)standards. These don't deal with structural design but the provide guidance on the fire size.
There's also Underwriter's Laboratories, which provides guidance on fire protection for structural framing systems in buildings
