OEM Hydraulic Valve HELP Looking for the Manufactures
Hi all,
i am looking for a pneumatic driven hydraulic valve made by OEM hydraulic (the name on the disc on the valve)It is used on the lubrication system as a directional valve.
Any help would be good.Thanks
Robert
RE: OEM Hydraulic Valve HELP Looking for the Manufactures
Do you earded abou search engines?
|They are useful, following the
Result when searching for OEM
 Búsqueda Avanzada    Preferencias    Herramientas del idioma    Sugerencias de Búsqueda
Buscar en la Web Buscar sólo páginas en español
 La Web     Imágenes     Grupos     Directorio
Se buscó "OEM hydraulics" en la Web.    Resultados 1 - 9 de 9. La búsqueda tardó 0.10 segundos.
OEM Hydraulics - [ Traduzca esta página ]
... UNDER-THE-HOOD HYDRAULICS. Below is a list of Trade
Shows where you can speak directly with a DewEze ...
www.deweze.com/calendars/oemhydraulics.html - 7k - En caché - Páginas similares
DewEze Products - [ Traduzca esta página ]
... Choose... Choose... Choose... Choose... ...
www.deweze.com/products/ - 13k - En caché - Páginas similares
Southern Ferro Ltd. - Clients - [ Traduzca esta página ]
... OEM HYDRAULICS Sterling Hydraulics. Avon International. Hypercision Hydraulic.
SPM Control. Siddarth Industries. SS.Industries. ELECTRO MAGNETIC OEM ...
www.sferro.com/clients.htm - 23k - En caché - Páginas similares
BD SENSORS - [ Traduzca esta página ]
... Applications, Features. 17.600, from 160 to 600 bar, 0,25% BFSL / 0,5% FSO IEC
60770, OEM hydraulics "Heavy-Duty", OEM-pressure transmitter with thin-film sensor. ...
www.bdsensors.com/druck_content.php - 26k - En caché - Páginas similares
sub-contractor, bar turner, automobile OEM, hydraulics - [ Traduzca esta página ]
... Our quality assurance. Since its creation in 1952,
the Pierre DUFOUR company has always ...
www.dufour-pierre.com/GB/qualitegb.htm - 10k - En caché - Páginas similares
Gas shocks - [ Traduzca esta página ]
... in that case. 2. Will having new gas struts in the front with older (OEM) hydraulics
in the back cause instability in corners? The car is a 5000 TQ. I was told ...
www.audifans.com/archives/1993/07/msg00160.html - 4k - En caché - Páginas similares
Re: [T2] Re: Hydraulic Lifters - [ Traduzca esta página ]
... some thoughts. On an aside I have come buy quite a few sets of OEM hydraulics recently,
and will sell a set for $60 plus shipping to anyone interested. I don't ...
www.type2.com/~type2reflect/msg36772.html - 6k - En caché - Páginas similares
O - [ Traduzca esta página ]
... OEM HYDRAULICS, INC. MANUFACTURERS. DAN PERONE. 1150
NEWARK RD. PO BOX 2969. ZANESVILLE, OH 43702-2629. ...
chamberon-line.com/new_page_42.htm - 28k - En caché - Páginas similares
Business Directory Online: Companies/Fabricators - [ Traduzca esta página ]
... OD, brazing, powder coating, Welding, Machining, Punching, Milling, Assembly. OEM
hydraulics, pressure vessel, and structural supplier. (Added: 16-Nov-1999 Hits ...
216.149.135.136/Companies/Fabricators/ - 8k - En caché
  Restringir la búsqueda a los resultados
Intente su consulta en:AltaVista Excite Lycos Yahoo!
Pruebe la Barra Google
©2002 Google
Pardal
Thanks i tried but no Google and i got many but not OEM
Thanks again
robert
Hi Robert:
Other thing to do is look at the Manufacturer label on the valve and see from where it is made: city and state.
I had reached  manufacturers throug the chamber of commerce of its city.
Pardal
Pardal
Thanks i found OEM But they have no website or so it seams will call them to contact them
Best
Robert
Try this site
www.doering.com
Bud Trinkel
Certified Fluid Power Engineer
HYDRA-PNEU CONSULTING, INC.
812-853-3234
fluidpower1@hotmail.com
