Thermal Conductivity of gas mixture
Hi, can someone direct me to a book, or website, whcih can show me how to calculate thermal conductivity and dynamic viscosity of mixture of gases?
My mixture consists of: Hydrogen, Nitrogen, Carbon monoxyde, Carbon Dyoxide, Methane and water vapor...
I need formula to calculate thermal conductivity, and viscosity..
Thank you for help in advance.
RE: Thermal Conductivity of gas mixture
There are procedures in the TEMA (Tubular Exchanger Manufacturers Association) book for calculating the properties of mixed gases. However, you need the individual properties to do it.
speco
http://webbook.nist.gov/chemistry/fluid/
But I'd recommend paying the $200 or $300 for the REFPROP database instead. It'll pay for itself very quickly if you do much thermo work.
http://www.nist.gov/srd/nist23.htm
In short, if you don't need a detailed discussion and references, this is what they suggest for gas mixtures at low pressures.
-thermal conductivity k=Σyiki(Mi)1/3/Σyi(Mi)1/3
-viscosity μ=Σyiμi(Mi)1/2/Σyi(Mi)1/2
where y is the mole fraction and M the molecular weight.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
thank you very much...And can you tell me, for water vapor, I need cp, thermal conductivity etc...On the net, I have only found values for 1 bar, and I have 21 bar at 210deg celsius?
Is it possible to find somewhere these values, or these values are available only for 1 bar?
Pay a visit to the site suggested by iainuts. You"ll find that water at 210oC and 21 bar is a liquid.
The Change of phase case involves absorbtion of(Latent)heat when boiling starts around atmospheric pressure.
Hope this is helping
Best Regards
Qalander(Chem)
At 21 bar and 215oC, the vapor Cp = 3.23 kJ/(kg.K), from the NIST table.
