stepped equation
stepped equation
stepped equation
I need to relate one dimension to another such that for a range of values of the 2nd one, 1st one has a single value. And for next range of values, the 1st one jumps to another value. Say, if x is between 50 and 99, y is 20 and if x is between 100 and 150, y is 50.
I can't find a way to do it. Can anyone please help?
Thanks.
RE: stepped equation
Think you need to set up a rule, check "Knowledgewarer Advisor" workbench. Haven't tried but it should work as you have written it:
if X> 50mm and X <99mm
    Y =20mm
