Corrosion rate of copper in vinegar
Please i will like to know the corrosion rate of copper in vinegar in terms of depth of material loss per year(mmpy).
RE: Corrosion rate of copper in vinegar
vinegar contains acetic acids in concentrations, usually, of 4-10%. from the data that i've found the corrosion rate for Copper for conc above 5% is >50 mpy.
hope this help
S
Corrosion Prevention & Corrosion Control
