Member Offset
Member Offset
Member Offset
Does anyone know When using MEMBER OFFSET command in STAAD the distance given is the distance from CG or shear centre?
What a bout open and unsymmetrical shapes where the CG and shear centre doesn't coinside?
Appreciate if someone could give an example.
