Copper line to transport acetic acid
Please i would like to know if using copper line/pipe to handle (5%)acetic acid would be okay and if increasing the flow rate of acetic acid could lead to higher corrosion or not. And what alternative do i go for if its not wise to use the copper?Please someone kindly help. Thank you
RE: Copper line to transport acetic acid
Here, try this http://www.coleparmer.com/techinfo/chemcomp.asp
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
http://w
corrosion resistance data
hope this help
S.
Corrosion Prevention & Corrosion Control
