Count how many parts in assembly that are the same part.
Sorry for making so many posts, but I have one more spot where I am stuck. I need the qty of each part in the active assembly. Currently I am looping through all the parts so there is probably just some code that i could put in the loop that would count how many parts of each there is. Any body done this before or got any ideas.Thanks.
RE: Count how many parts in assembly that are the same part.
There's no way I know of to directly get the component count through the API.  You will have to somehow count 'em up as you loop through the tree. One way to do this would be to use the Excel list you are making.  I assume you are wanting to put the quantity in there anyway in some other column.  Basically, before adding any part to the Excel list, loop thru the Excel list and see if the part number already exists in the list.  If it does, increment its qty column instead of adding it to the end of the list.
-handleman, CSWP (The new, easy test)
Hmmm.. Dummy of BOM that is interesting had not thought of that, I'll see if I can pull that off. If not then I might just go with checking to see if it already exists in the excel sheet like handleman suggested. Thanks
bguenther,
Which version of SW are you using?
SW2009 has a built in "BOM from assy model" function.
cheers
I have used the dummy drawing with a BOM also. You can keep it and update it, and always go back to it.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
CorBlimeyLimey,
I am using SW2008 SP4.0. So you just make a drawing add a BOM and read the QTY column and then I would use that to put in my excel sheet ?
Yes, for SW08 ... or you could use the macro TheTick suggested, to create the BOM directly from the model. No drawing required.
SW09, has that same function built in.
cheers
I have used the custom filter at the top of the feature tree in an assembly to see all of the instances in an assembly.  It's more of a quick and dirty way instead of creating a BOM.
I'd recomend using the macro TheTick suggested.  It gets the component count (and other properties) and will export it to a spreadsheet.  You should be able to extract some code from it.
Joe
SW Office 2008 SP4.0
P4 3.0Ghz 3GB
ATI FireGL X1
I guess I am pretty dumb because that macro is very confusing to me, I can't figure out what code is all needed to do that job.
The Advanced Select Functionality might be able to do this. You can set filter criteria like Volume = Value or Component name contains "WORD" and then use that to select the components and get a count of the objects selected.
In 2008 you also might try the Assembly Xpert which can count the number of components that are unique parts or configurations.
Michael
I guess it is sort of , sorry I did not intend on this being a repost.
I certainly didn't mean that it was a repost, because it is a slightly different question and this is really the best place for it.  However, people were giving answers that either had already been given or were not necessarily in the direction you were looking to go, based on information in the other thread.
