Changing Text via dimension or Design Table
Hey,
I have to create about 80 of these parts with a few different dimensions, and I need to change the text on each one.
I can't seem to get the text value in a design table.. Does anyone know a trick or anything?
OR can I have it link to a dimension in the model (the radius of the curve)
RE: Changing Text via dimension or Design Table
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
FAQ559-1100: How Can I Show An Image In A Post
FAQ559-1177: How Do I Make Files Available For Download? ... No Emails Required
-handleman, CSWP (The new, easy test)
I have no idea how to write macros.....
if i just copy and paste I lose everything
http:/
Basically, they created a sketch which had all the text variations in a column. Each set of adjacent text was spaced sufficiently to clear the model. The sketch position was controlled by a DT which was used to shift the sketch text into position.
That trick worked great!! thanks man
Saved me alot of time :)
