Pattern Table?
Pattern Table?
I have a hole in a plate dimensioned in the X & Y from two common edges. I'd like to create a pattern of the hole in the X direction such that all the dimensions come from the common edge. In other words, ordinate dimensioning so i have X1.00, X2.25, X2.50, X2.9, etc...
For the Pro/E to UG converts, I want to create a Pattern Table.
Suggestions.
NX5.
Suggestions.
NX5.
Fighter Pilot
Manufacturing Engineer
RE: Pattern Table?
kukelyk
RE: Pattern Table?
Cheers
Hudson
RE: Pattern Table?
Yea, I knew I could do the point placement thing but that's lame. Pro/E allows you to whip out a pattern table in seconds flat and you keep the design intent. Plus, I get to show, not create, the dimensions in a drawing. I'll add this to the list of other things UG doesn't do well compared to other systems.
I'm really beginning to think the developers at UG have no idea of what "design intent" really means.
Just venting...
Fighter Pilot
