Vertical Text
Vertical Text
Vertical Text
How to create verticle text (see attch) in drawing annotations?
I dont see any options in the format text dialog box.
C1
RE: Vertical Text
L
I
K
E
T
H
I
S
David
RE: Vertical Text
Seriously though there isn't an option to do this in inventor (unless they added it in 2009) but you can get an addin from here:
http://www.cbliss.com/inventor/iCode/index.htm
called 3DText Add-In that will do this. I haven't tried it with any releases after IV11 so it may or may not work.
David
RE: Vertical Text
True. They havent added it in 2009 too.
I wish they had a option for this within text formatting.
RE: Vertical Text
You could always just hit enter after every letter and then give them a center justification.
Not what you're hoping for I'm sure... But it works.
