What are "staked" bolt threads?
In the 1983 AISC article "Design of Headed Anchor Bolts" by Shipp and Haninger, it states:
"Where plain bars are used, the equivalent anchorage may be accomplished by threading the embedded end of the bar and using one heavy hex nut with bolt threads "staked" at two places below the heavy hex nut"
What does "staked" mean in the application?
RE: What are "staked" bolt threads?
DaveAtkins
Ted
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
This might help.
Staking- Staking is a method of fastening (usually sheet metal) by squeezing protrusion formed in one part inside a hole in the second part, and then deforming the protrusion. The act of deformation causes radial expansion of the inner part and locks it in the hole.
Can anyone confirm Hogan's definition?
Hogan: Where did you find that?
Cheers,
YS
B.Eng (Carleton)
