Association Beam Elements with Solid Elements in Hypermesh
Hey all,
I hope anybody can help me. I want to connect beam elements which are crossing a cube with the solid elements of the cube. Unfortunately Hypermesh does not use the ends of the  beam elements for the integration into the mesh of solid elements for the cube. I have tried to create separate surfaces in the cube, which containing the beam elements and I created fixed nodes, but the geometry is getting to complex...
Is there an easy way to combine this types of elements with a mesh in Hypermesh?
Thank you very much for your answers and help!
RE: Association Beam Elements with Solid Elements in Hypermesh
You need to build a spider of beam elements or rigids (I advise not to do that) between the end of your beam and several nodes on the solid elements.
You should validate your chosen method, it is a horrible bodge, but it is possible.
I doubt the local stresses will mean very much. I don't use FEA for stresses.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
