Preservative Grease
Preservative Grease
I've learned that my old favorite preservative grease RIG is no longer made .I've used it for many years for tools and firearms and I'd like a replacement .Anyone familiar with RIG who can suggest a replacement ?
RE: Preservative Grease
http://www
Here are some alternates for you guns from my brother the gunman.
He did use Corrosion Block exclusively but has switched to the CorrosionX product. For his so called permanent storage he uses Molykote Metal Protector Plus. Corrosion, at my recommendation. Corrosion Block does have a grease if that is preferred.
http://corrosionxproducts.com/cxforgunspage.htm
Lear Chemical is the actual maker of this product.
http://www.corrosion-control.com/index.html
http:
