Maintenance techniques on medium voltage contactors.
During a recent shutdown we removed an old GE limit-amp starter from service in order to check the condition of everything. The contacts looked to be in good condition, and we used Scotch-brite to shine them up a bit.
Is Scotch-brite recommended for cleaning any contacts? Low voltage; ie.
Also the stabs for the 4160/120 control transformer had a buildup of black crud on them and were not making a good connection.
Was this crud whats referred to as carbon tracking?
We were unsuccessful in cleaning this off using delicat methods, and had to resort to using a wire wheel to get it off. The silver plating is now worn off, and there are a whole bunch of pits in the stabs where the black crud was. They are making far better contact than before, but I question the "techniques" we used to clean the contacts and the stabs.
When I asked for replacement parts, I was informed that they were obsolete and to do the best we can until a new starter is in the budget. This could be several years. We have not brought this motor online yet, and I'm concerned that we will have problems down the line.
I thoroughly enjoy having the opportunity to work on this large equipment, but finding guidance on some of the inside tricks is difficult. I try to read as much as possible, but for every useful book i find there are 5 useless one.
RE: Maintenance techniques on medium voltage contactors.
We rebuild these everyday in our shop, buying a new one is a waste of money.
BTW, I stock replacement parts for those. Not a problem, contact me if you still need them.
Scott
www.cbsnuclear.com
Tom
None of us is as smart as all of us.
That paint on silver plating stuff is a temp fix that wont last long. You are on the right track with the tin plating, here are some other solutions.
Tom
Corrosion is definately not a problem at the plant. the small amounts of cement dust present in the substations doesn't seem to bother anything. We clean all the equipment thoroughly quite often.
Tom
I have parts for those
Tom
Scott
www.cbsnuclear.com
scotch brite pads and (if you're good..) needle files are a good way to dress contact buttons and remove scale, tho.. good call on that.
We have the large one the guy is standing next to.
When we do something we do it right, we also have a 24 foot Big Ass Fan http://www.bigassfans.com/ to cool the shop
http://photos.gcbsinventory.com/trailers/
