steam flow rate and pressure
hi guys
i need a standard values for steam flow rates and presurres to different applicatin uses steam at hospitals laundaries, etc.. from a refrence like ASHRAE for example
thanks
thanks
RE: steam flow rate and pressure
Here, try this:
http:
Ciao,
HevïGuy
www.heviitech.com
I seem to recall a compendium of equipment steam rates but I've no idea where that may be. Even this wouldn't be very good to you since rates depend on the size of the component, heat rise etc (hence the link giving you the opportunity to calculate consumption based on actual parameters)
Couple of suggestions:
Ciao,
HevïGuy
www.heviitech.com
