BUILT-UP COLUMN
BUILT-UP COLUMN
This is an Industrial type structure where we have 2 nos. 40' high columns spaced closely and these column need to act as one section for axial and bending.
The web of one column is oriented 90 degrees in reference to the other column( i.e flange of one column is facing web of other column.
For some reason(one of them is size of columns are different W24x68 and W18x40) we can not provide lacing or battens to join columns together.
My question is :
If we connect the 2 W shape columns(with 2 feet c/c spacing in between) by "horizontal" W beams, will this be a "BUILT-UP SECTION" or not?
The vertical spacing between W beams will be approx. 4-5 feet. The W beam will not be rigidly connected to columns.
If not , is there any other way to make these columns to behave as built up section so that there combined properties can be used?
RE: BUILT-UP COLUMN
RE: BUILT-UP COLUMN
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
http://www.eng-tips.com/supportus.cfm
