blending CYLINDER with BLOCK???
Hi guys,
New UGS NX6 user here.... I had a quick question.
How do you do a blend with a cylinder sitting on top of a block in NX6?
Let's say my cylinder is 50mm dia (length does not matter) sitting on a 100mm X 100mm Block (thickness not important)...
I know how to make them unite with a boolean operations, but I have been unable to make a nice rounded blend between the 2???
THANK YOU ALL>
Max
RE: blending CYLINDER with BLOCK???
John,
Thank you very much for the quick reply.
I tried your model and it worked perfectly. Somehow I must have not done the unite prior to blending them (although I thought I did).
Thank you very much.
Max
