Adding a PDF & DXF dataset to TeamCenter
I am wondering if anyone can help me to be able to add a DXF & PDF dataset to an item in TeamCenter? When we create a plate drawing, we generally send our supplier a PDF copy of the drawing and also a DXF file for laser-cutting. We would like the ability to be able to lock these two files down with the item revision when it is signed-off.
Currently if we go to add a new dataset for a DXF file, we find that the DXF file-type is not available from the dataset drop-down box, hence we cannot add a DXF.
When we go to export a PDF copy of the drawing file from NX, we get a message saying:
EXPORT PDF
TEAMCENTER ERROR: DATASETTYPE PDF IS INVALID.
Is anyone able to offer any insight as to how we would go about this? Many thanks
EXPORT PDF
Ross
NX6.0.1.5 WinXP SP2
SolidWorks 2007
RE: Adding a PDF & DXF dataset to TeamCenter
Best of Luck
Hudson
Ross
NX6.0.1.5 WinXP SP2
TC V10.0.2.4
SolidWorks 2007
Cheers
Hudson
DXF can be drag and dropped from Windows using the text dataset. (DXF is just a text file after all).
NX 5.0.5.3
TC 10.0.2.6
