Test for file open by another app ?
Is there an easy way to test to see if a file is currently open by another application ? I am working on a VB project that requires the file to not be open before I access it. (I am using DSOFile (from Microsoft) to access document properties)
RE: Test for file open by another app ?
This is not a Professional solution !.
You know that if a file is already opened, it could not be deleted. So you can copy the file to a temporary one and try deleting the original file , if the delete operation failed, this mean that the file is used by another app. , if delete success rename the Temp. file to real name and countinue working on it .
I want to thank you for the tip. Nobody else was willing to try this one, but you were ! Although I think it's a little risky to be deleting Soldworks files while someone has them open, you were the only one that responded. Thanks again.
Don Michaels
on error resume next
Open "MYFILE.TXT" For Output Lock Read Write As #iHandle
if err.number <> 0 then
'THE FILE IS IN USE
else
CLOSE #iHandle
KILL file.txt"
endif
on error goto 0
What the above snippet does is to try an lock a file. This will fail if the fail is already locked by another application. You need to keep in mind that some applications don't lock the files, so there is no indication that the file is in use.
Troy Williams
fenris@hotmail.com
Open the file and check to see if it's Read-Only.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
--Start of snippit
Public Sub RemoveFile (strFileName as String)
On error goto fileError
Kill strFileName
goto hurrah
fileError:
if err.number = 75 then
'file/path error - probably in use
else
'something else went kaka-kookoo, mebbe we'll throw
' it back up the call stack and make it someone
' elses problem
err.Raise err.Number, err.Source, _
err.Description, err.HelpFile, err.HelpContext
end if
err.clear
hurrah:
end sub
---END of snippit
No true coder likes goto statements, but Uncle Bill makes us use 'em anyways. If the file isn't locked, then the app doesn't really have it 'open'. It just read it, and will probably re-write it completely on a save.
