label hand drawn contour polylines in civil 3D
i have always been using the label contours function in LDD to label my contour polylines. i do not see that feature in civil 3D. is there a way to do the same thing here? labeling contours group interior, group end etc. i used to use terrain>contour labels in LDD before.  i do not want to create a surface first to be able to label contours.any suggestions appreciated.
RE: label hand drawn contour polylines in civil 3D
No can do without creating a surface using C3D labeling tools
but here's a lisp... you'll need to edit the layer and text style
CODE
; Annotate a Contour Line
; BY: Tom Beauford - 7/11/2005 w/ revisions by LPS 8/4/2008
; (load "ContourAnnotate.lsp") LCM
(defun c:lcm (/ mspace om osz e ent pt tblname Rot str mtextobj ent el)
  (setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
            om (getvar "osmode")
            osz (getvar "osnapz")
            clay (getvar "clayer")
            txtstyle (getvar "textstyle")
            txtsize (getvar "textsize")
  (setvar "osnapz" 0)
  (setvar "osmode" 512)
  (command "ucs" "w")
  (setvar "clayer" "FG-CONT-ELEV")
  (setvar "textstyle" "simplex")
  (setvar "textsize" (* (getvar "dimscale") 0.1))
  (setq pt (getpoint"\nSelect point on Contour Line: ")
            e (nentselp pt)
            ent (car e)
            pt (cadr e)
            tblname (car(ade_odgettables ent))
  (setq Rot (getangle pt "\nPick or Enter angle..." )
            str (rtos (caddr pt) 2 0))
  (ade_errsetlevel 2)
  (if(ade_odgettables ent)
    (cond
      ((ade_odgetfield ent (car(ade_odgettables ent)) "ELEV" 0)
      (setq str (itoa(ade_odgetfield ent (car(ade_odgettables ent)) "ELEV" 0))))
      ((ade_odgetfield ent (ade_odgettables ent) "ELEVATION" 0)
      (setq str (itoa(ade_odgetfield ent (ade_odgettables ent) "ELEVATION" 0))))
  (ade_errsetlevel 0)
  (princ "\nElev = ")
  (princ str)
  (setq mtextobj (vla-addMText mspace (vlax-3d-point pt) 0.0 str))
  (vla-put-attachmentPoint mtextobj acAttachmentPointMiddleCenter)
  (vla-put-insertionPoint mtextobj (vlax-3d-point pt))
  (vla-put-Rotation mtextobj Rot)
  (vla-put-Color mtextobj 256)
  (vla-put-backgroundfill mtextobj :vlax-true); mask on with background color
  (setq el (entget (vlax-vla-object->ename mtextobj)))
  (setq el (subst (cons 45 1.05) (assoc 45 el) el)) ;Set MaskSize 1.05 × TextSize
  (entmod el)
  (setvar "osmode" om)
  (setvar "osnapz" osz)
  (setvar "clayer" clay)
  (setvar "textstyle" txtstyle)
  (setvar "textsize" txtsize)
  (command "ucs" "p")
  (princ)
____________________
Civil 3D 2008, Terramodel
