Tool Path Generation defaults
Can anyone help me to change the defauls on the Tool Path Generation prompt?
See attached file.
I want to "uncheck" the pause after each path option and have that be the default forever and ever.
I looked in customer defaults but I could not seem to find anything.
Jay
RE: Tool Path Generation defaults
Jayden,
This is something that is set in the operation.  You could edit the template files and uncheck this option from the "default" operations and never see it again.
You can change the manufacturing Preferences - Operation to ucheck this so when you generate multiple operations it does not happen.  Yes you would think it would be in the customer defaults but I can't find it.
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
Thanks you!
That is perfect!
