Backflow Pressure
Backflow Pressure
Backflow Pressure
Anyone have a good reference formula for calculating backflow pressure for a capsule like feature?...in other words, picture this: if you were to take a tylenol pill, cut it in half, and laser cut a quantity of 50 .004" diameter circles around the cylindrical face, how would one calculate the backflow pressure given a known flow rate?
Thanks!
RE: Backflow Pressure
Sorry, I can't picture it in my mind.  How about a sketch?
Good luck,
Latexman
why not make one and flow test it.
The formula for orifice pressure drop is probably for holes thru a flat surface whereas you are talking about hole thru a cylindical surface meaning the holes are not of an area equal to 0.004" dia. if it were a flat surface. You could of course calculate the actual area and use it in any formula.
The application I have in mind is similar to a shower head - with many tiny holes in it: roughly .004" in diameter...so if there is a formula to calculate such backflow or back pressure, that would much be appreciated!...
Thanks!
What is the L/D of these 0.004" holes?  L would be the thickness of material the holes would have to penetrate.  This will determine whether it is treated as an orifice or a small pipe or tube.
Good luck,
Latexman
Did you refer to the posting from MintJulep - you need to have some input as well - not just ask questions.
