Realview Issue at Assembly Level
Hello all,
I am having strange issues with Realview. My parts display Realview correctly but when I use then in an assembly the only difference between Realview and not is the reflection under the assembly. Basiclly the components lose the Realview look at the assembly level. Small assy about 10 parts and I have LAM turned off as well. Thanks for any suggestions. My specs are as follows:
SW2008 sp4.0
Dell Precision T3400
Core2Duo 3.15GHz
XP x64
nvidia QuadroFX 1700
8GB RAM
SW2008 sp4.0
Core2Duo 3.15GHz
XP x64
8GB RAM
RE: Realview Issue at Assembly Level
thread559-211718: SW2008 Real View Explained
CBL, NICE file that goes in depth more than I have seen before regarding the usage of RV. However, after review the entire file I see no reason for the current behavior of my Realview, unless I missed it :)
Thanks BB
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
What I did is apply a material "Chrome SS" for each component and modeled them with realview turned on. I have applied no textures or other appearances. In fact, at the part level, turning on/off the realview does not always change the part either.
Hope this will help VIMS issues as well.
BB
Which video card and driver are you using?
I guess with SW packages that don't have PhotoWorks, RealView would be an asset. But with PhotoWorks--and now PhotoView360, I really wonder what's the point in having all these different types of displaying material properties within SolidWorks. Seems a rather fractured approach.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
